I would like the ability to be able to use design components such as lines and callouts on a modal layout. I would use the callout to add instructions for the user and the lines would be to just add a visual breakup between columns.
This would be a very handy feature!
Yes, would be very useful too to have the ability to add section and title of sections. Currently, I’m doing it by cheating a little bit but I think that can match your need.
Titles circled in red are always the same and I’m using it + some line breaks to have a visual break.
Came here to bump this request - please give us lines in modal. I’ve been hacking with the Rectangle() formula for a while, but recently the lines (thin rectangles) haven’t been loading on 10-20% of modal openings.
@Aurelie_Pureur how are creating those titles in your modal?? Are they just extra columns with plain text that you’re displaying as headers with the columns title hidden?? Looks great!
You can look at this demo doc to see how it is done (open and make a copy):
Absolutely, just columns with text styled like headers. ![]()
