I need a formula that will take the text in one column and create variations of that text in a separate column. The variations would be different capitalizations/lowercase and character differences(and vs &).
Here’s a breakdown…
Here’s a breakdown…
Instead of generating all possible variations of text you should rather find a way to normalize both the submission and the answer to some common variation ![]()
RegexReplace("\s+", " ")
RegexReplace("[^\w\s]", "")
& with and using the same method.Lower()
Answer.ContainsText(Expected, true, true) — this is a cool function because it’s also capable to ignore variations in áccénts, not only letter case, i.e. returns true on “fjällräven kånken” containing “Fjallraven”
