Formula Help for Date Reference
I followed the tutorial on how to add a change history/log history to an item. Now I’m seeing a strange error.
Capture
What is being returned is two dates. There should only be one in each cell.
Capture
How would I get it to restrict to show just the single date?
you would use either .First() or .Last() to pick an appropriate entry -
(I am not entirely sure what your business logic is - but if you expect to have multiple entries in Borrowing History for a specific borrower - you would get multiple Date Needed and then you want to sort and use .First or .Last depending on whether you want latest or earliest entry
Thank you for responding. What I’m trying to do is have three tables connected (Book, Borrower, Borrowing History). Therefore, when you look at the book Layout display, you get a nice embedded table showing the list of previous borrowers (in descending order). For e.g.
Borrower ----- Date Borrowed
DEF -------------2/11/2019
ABC -------------1/1/2019
If I don’t add .first(), I get the bad dates shown above. But if I do, I get the date for the last book borrowed that person took out – even if it isn’t for this particular title. I’ve tried to modify the formula to refer to this title, but that gets me nowhere either.
Capture
I appreciate any pointers.
By the way, you wouldn’t have a guess as why the Borrowing History table that is embedded in a Book row will display as a table most of the time, but not always? In one of my Books, the Borrowing History shows up as a list of tags. The code is identical in all cases…
Not entirely following the problem - but my guess is you are showing Books with details layout (the picture in your post) but you are comparing Borrowed By (which i assumed to be the person who borrowed) to thisRow (which is a book?)
here’s an example, if this doesnt work, please share your document with support@coda.io and ask for me (Krunal) and would be happy to take a look
