Formula Help: Is This Possible?
Please help with this formula for a filter (if this is possible).
I have two date fields, startdate and enddate.
For the filter I would like to use:
Include this row when:
If the field enddate is populated and its value is greater than today.
If the field enddate is not populated, then if the field startdate is greater than today.
I’m having a little trouble getting my head around this, but Coda has quickly became my go to app!
Thanks for any help!
Hi @Chris_Hall :blush:
Is this what you were looking for ? :blush:
(thisRow.enddate.IsNotBlank() AND thisRow.enddate > Today())
OR
(thisRow.enddate.IsBlank() AND thisRow.startdate > Today())
Edit : The explanations are :point_right: here :innocent:
Yes!
Thank you!!!
I think I’m beginning to understand formula a little better now!
That’s great to read :raised_hands: !
And you seemed already really pretty close to make it work by saying this :point_down: @Chris_Hall :raised_hands:
If I decompose your sentences, this is what I read (and how I ended up with the formula) :blush: :
Step 1 of the filter:
  • the field enddate is populatedthisRow.enddate.IsNotBlank()
    AND
  • its value is greater than todaythisRow.enddate > Today()
OR
Step 2 of the filter:
  • field enddate is not populatedthisRow.enddate.IsBlank()
    AND
  • the field startdate is greater than todaythisRow.startdate > Today()
And the whole filter works like this :blush: :
  • Step 1 will return True and keep the rows where both conditions thisRow.enddate.IsNotBlank() AND thisRow.enddate > Today() are True
  • Step 2 will return True and keep the rows where both conditions thisRow.enddate.IsBlank() AND thisRow.startdate > Today() are True
The whole filter will return True and keep the rows in the table for which either Step 1 OR Step 2 has returned True :blush:
How did you get all that cool button like formatting on your response???
Hehe :joy:
I used the <kbd> HTML Tag :blush:
(which is the tag used generally to display keys from a keyboard where one would think it’s needed… mostly on GitHub :blush: … At least, that’s where I found it)
  • <kbd>⌘ Cmd</kbd> + <kbd>c</kbd>
    ⌘ Cmd + c
  • <kbd>⌘ Cmd</kbd> + <kbd>⇧ Shift</kbd> + <kbd>v</kbd>
    ⌘ Cmd + ⇧ Shift + v
Today I learned :smiley:
To meet the 20 character rule, wondering if <blink> tag would work. blink (edit: nope)
