FormulaMap for creating multiple rows
Trying to Add a row to a table for every item in a list but cannot make it work:
See screenshot below. Any suggestions?
First, remove CurrentValue from within the FormulaMap.
Just [Add These].FormulaMap(AddRow(...)).
Secondly, there’s still a bug with CurrentValue within AddRow. It will work, but the formula will report as broken. See here:
If you’re just inserting CurrentValue, you can ignore the error, the action will work correctly. But if you need to dereference columns from CurrentValue, use the _Deref() trick mentioned there.
Thank you! It worked!
Hey @Paul_Danyliuk :wave: hope all good?
I am not sure if my problem is solved already with this post, what I am trying to do is to propagate a new table with 2 columns; one with one value and the other with 1-n values
Finally I want to have this result (for each region and category one row)
This formula is not working:
r_region.FormulaMap(AddOrModifyRows(r_category,Region=Region and Category=CurrentValue.Category,Region=Region,Category=CurrentValue.Category))
Any suggestions?
Thomas
Hi @Thomas_Schulz,
Unfortunately it’s not trivial because of nested loops and the current limitation of the CurrentValue at the lowest level scope.
If it’s acceptable for you, a workaround could be to split it at a row level.
Try to have a look and see it it fits your needs.
Not as elegant as a single formula, but it actually does its job.
Let me know if it helps.
