Formulas for Individual Cells
Is there a way to create a formula for an individual cell in a Coda Table?
Gold | 24% | $
If my table has the asset name: gold
The percent of my investment funds that i want to allocate to it
then how can create the “$” column so that each row multiplies my “Total Investment Funds” (which is in another table) by the “%” column?
Each Asset name has a different correlating percentage so i cannot create one formula for the entire column.
I don’t think there’s any way to program cells yet in Coda, unfortunately
You could do a workaround using the SwitchIf formula by specifying the RowID and column that you want to modify
SwitchIf(If rowID = x and column = y then expression, If rowID = a and column = b then expression, If rowID = c and column = d then expression, etc)
Another question:
$ goal | $ actuality | $ exceeded or missed by
Example
$100 | $90 | -$10
how can i create a formula for my “$ exceeded or missed by” column so that it takes the “$ actuality” column and subtracts the “$ goal” from it?
I have tried the obvious: (Table Name.$actuality) - (Table Name.$goal)
but it did not work
Oh, well i fixed it by simply not including the name of the table before name of the column, which i find odd since that is how i would normally express them in a formula.
thanks so much anyway!
Would this not work?
thisRow.[%] * OtherTable.[Total Investment Funds].value
I’m having a hard time envisioning what your tables all look like without examples, but it sounds like you’re not really asking for per-cell formulas–it’s just that that’s one way of reaching your goal. But
  1. Coda by design doesn’t care about “cells” and has no idea what cells are; Coda’s smallest unit is a row.
  2. Even if it did support individual cells, using them is more-often-than-not a symptom of unsustainable table design
There’s usually a more elegant solution to be had in table relations.
that did work! thanks so much! really appreciate it!
