Hello,
I first do apologize for my bad English as a French beginner in Coda.
Is it possible to have the Sum of a Sub Item’s value (or an another formula) in the same Column of the Parent’s one ?
Hi Emmanuel,
Welcome to the community!
Yes, it’s quite easy actually, you just have to create another column and add the formula subitems.Montant.sum()
Here you can see a little demo
