[Free] - Hour Long training/assistance for your docs, formulas, etc
:wave: Hey there!
tl;dr
Im going to hold an hour long completely free Coda session next Tuesday the 22nd at 9:00am PST to help you get unstuck on your doc (help with a specific formulas, doc design, user-interface design. . . You name it!) If you would like to sign up, you can do so here → Sign Me Up
To make it more worth your while, I am limiting sign-ups to the first 5 individuals so if you make the effort to show up, you know you will get some quality help.
If people are interested and you find value in it - I may hold these more often as well!
Why am I doing this?
I wanted to try something new - I love helping individuals get unstuck and build the doc or solution of their dreams in my Coda consulting practice. My only regret about my job is that I don’t get to connect with or help everyone!
Thats why I am going to start something I am calling GetUnstuck.
What is it?
GetUnstuck will be an hour long open Zoom call limited to the first 5 people to sign-up to ensure if you make it, you really get the help you are looking for. Come with your questions, your docs and get help with:
  • Writing specific formulas
  • Automations
  • Doc schema design and mapping
  • Visual design and UI/UX
  • Doc optimization (making those large docs quick again!)
Why am I qualified to help you?
I work full-time as a Coda Consultant and have literally built thousands of docs and have worked with individuals and companies in dozens of unique sectors all across the world.
If Coda can do it, I can help you make it happen.
Looking forward to seeing you and helping you GetUnstuck
Only one spot left! Looking forward to seeing all you who signed up tomorrow
This is awesome Scott!
Good luck Scott!
Speaking from my consulting practice it’s pretty tough to give some quality help to one person in just an hour, let alone five people. Very often those docs have serious fundamental problems. Fixing a formula or two won’t make a drastic difference. Even if it does, it’s not enough to educate the maker about how to avoid similar problems in the future.
Won’t say it’s totally impossible though. Sometimes identifying and fixing just one bottleneck could help the doc significantly. So stock up on caffeine and good luck :slight_smile:
BTW would you mind if I joined if I happened to have time tonight? I promise I won’t interfere unless you ask me to :slight_smile:
Hey Paul! I like the optimism! Im always up for a challenge.
Sorry Im just responding now - Just seeing this!
No problem :slight_smile: So how did it go?
Went well mate! Ill give a more thorough run-down in a post later - definitely going to do some more if anyone is interested!
This was AWESOME! Scott was super helpful breaking down formulas in a way I understood them, and that was directly applicable to my doc setup. I’ve been using the suggestions to retool my doc and it’s MUCH better. Thanks again!
