geographic coordinates and google maps
good night guys, so I already saw that you can put maps … but that adding the geographic coordinates that we took from google, would be more precise and so I could leave my address list more accurate
Coda supports GPS coordinates in the GoogleMap function. Look at the second example under that formula.
If you have the geo coordinates, we can render it on a map.
Is that what you had in mind?
Hi
What is the current status of the GoogleMap function ? I can’t seem to find it in the functions reference guide.
I see the Spatial section with distance and location functions but not anything that looks like a Googlemaps function.
Thanks
Dear @Karl_Niemann
Hopeful this link gives you what you are looking for GPS Coordinates
Amicable,
Jean Pierre
Hi,
There is no GoogleMap function documented there? Is this not supported anymore?
Thank you
Dan
Bumping this, has Google Maps functionality been removed?
To answer myself, it’s been moved to ‘experimental’.
Guess that means they remove it from documentation and hide it from the autofill list, but it still works. See below for how to use.
Hello everyone,
So it looks like googlemaps-coordinates have really been removed?
Would be a really great to have that integration again.
Still works for me as described above
@Josh_Unwin1 I realized it too a few weeks ago.
What I’m still missing though is mapping out different places into a googlemap. As far as I can see this is not possible.
You mean multiple pins on a single map view? Yeah, that would be nice.
Yes exactly, multiple pins on a map.
At best connect maps with pins I created on googlemaps to adminstrate in coda.
So if you add a place in googlemaps to a map you will also have it on coda.
That would be so so nice!
