Get CurrentIndex of FormulaMap loop?
I have a list that I’m running through FormulaMap()
And I’m trying to apply a consecutive growth factor of 1.1 to every item in that list.
So if each item in the list was $1, the output for 3 loops of FormulaMap would result in:
$1.1
$1.2
$1.3
But at the moment, my current results are:
$1.1
$1.1
$1.1
So if I could get the CurrentIndex that the FormulaMap was processing (similar to CurrentValue), then I imagine using that in the multiplier equation. CurrentIndex would sort of be a reverse Nth().
Alternatively, is there a math equation for this type of scenario? Like a Log() or Power()?
Many thanks.
@Michael_McGreal
Please show the exact math for the calculation you want to perform inside FormulaMap().
Hi there Ander,
Thanks for your help.
Here is a video showing the exact math.
Text version for quick reading/skipping is timestamped in the video description.
Many thanks,
Michael
@Michael_McGreal
I think you had the right idea: https://coda.io/formulas#Power
Hi Ander,
It took me a couple tries to get to your answer. The sequence(), and order of operations in the Power() formula make this a superb solution.
Many thanks my friend :+1:
Michael
Interesting project!
Wow. Just wow. Thanks.
+1, Notion has also added support for many loop functions, Coda needs to support some more advanced features.
You could use Withname() for nested loops…
