Get rid of deleted rows in relation columns
Hello!
If I delete a row, its “ghost” still appears in any relation column that it was in:
Is there a way to prevent this from happening or remove them completely?
You can remove them by clearing the value on the relation column for each of the affected rows.
You can get all rows with “ghost” values by filtering your affected table with: Source_Relation_Table.Contains(thisRow.Relation)
Then you can set them all to blank or to a different value using ModifyRows.
Hi, im running into this problem but i dont get your solution. I already have several linked records and deleteds in between, cant erase everything!
appreciate your help :slight_smile:
so i switched the linked column view from open button to value and then i can see the deleted ones and then went one by one :roll_eyes:
A better way to remove “deleted” rows is using the IsFromTable formula, something like this
thisRow.ModifyRows(
    Relations,
    thisRow.Relations.Filter(CurrentValue.IsFromTable(RelationsTable))
