Hi. I’m a newbie so forgive me if this is obvious. I installed the Simple Gmail CRM pack, and have a Contacts table and a Threads table. I would like to filter the Threads table to include only emails To/From the recipients listed in the Contacts table, without having to add each email address to the filter manually. Any step-by-step guidance here would be much appreciated!
Hi @Jonathan_Landau,
Can you take a look at this example and see if it helps you
