Gmail Pack - Sample Code?
Hello, I was interested in getting a two-way communication between gmail and coda established. I thought the existing coda-developed pack would be a great place to start, however, it wasn’t included in the list of samples in the pack developer. I was wondering if anyone had this code, or had suggestions for how I could get this code?
Thank you,
Adam
Hi @Adam_Romary - Excited to hear that you are interested in building a Pack! The code for the official Coda-made Packs isn’t public currently, and the sample code in the docs are new Packs created specifically to help folks learn.
Regarding Gmail specifically, Google makes it VERY difficult to get access to the Gmail API, including a security review. I’d probably recommend that you get feet wet with another Pack first.
Got it, thank you. Adam
