Google Sheet to coda ( Column Sync issue)
Hey Guys, My google sheet to coda is setup through goole script and running with no error but somehow not data from each row is showing on my coda doc!! Few columns quch as quarterly revenue are able to sync with google sheet but monthly revenue columns are empty!!
Any help!! Thanks in advance
Hey there!
We’re going to need more information (shared link to doc, screenshots, etc) to give you help!
Couple tips:
  • Make sure the names of the column are exactly the same in each area
  • Sometimes that script does silly stuff if the Coda table you are syncing to is not a coda native table (if its a sync table, etc)
