Hi…
I am new to Coda and not particularly savvy when it comes to formulas and filters…but I figured out something that might be useful for others:
I have a large database of disconnected information, sort of call notes from every call I do. I have found Coda to be better overall at handling this kind of info than Evernote or Keep.
I wanted to be able to quickly filter through all the records of calls to get to records with one person or one organization.
I created a view that shows all records in the database, but the search function in the upper left makes you go through the records one of a time. I wanted a filter, instead.
So I did a couple of things:
I created a new column called Full_text with a formula that combines all the relevant info into this column separated by commas and in lower case: Lower(Who+", “+What+”, "+[Notes (Paste from below)])
Then I figured out how to filter this info, with a filter like this: Full_text.RegexMatch("")
This filter is case sensitive, which is why I converted everything to lower case in the new column. (I think this is why the new column with all text converted to lower case is necessary)
I use Keyboard Maestro, so I made a keyboard shortcut for this filter that pastes Full_text.RegexMatch("") and then arrows back two spaces to put the cursor between the “” so I can trigger my keyboard shortcut and just start typing what I want to filter.
Works great for me and it was fun to figure out, I hope it helps others.
Overall, Coda has been an incredible gift for us.
Gregg
Neat trick @Gregg_Stebben, thanks for sharing it! Would you mind posting a screen capture of the result, or even sharing a sample doc?
Would also love to make this scenario more easily - if you could quickly to filter any table, would that meet the same need, or would you want something different? Would you want to the search filter to go across all columns, only certain columns, or would it depend on your scenario?
Hi @nathan.
I would love something similar.
I imagine this could be done adding an input/search control and then choosing which column do you want to filter. This would be a nice feature allowing simple searches/filtering in any given table.
I am trying to use the LOWER() to combine columns like above but I get a weird output that has the word grid mixed into it. I think it may have to do with the fact that the columns I am trying to combine are look up columns and a selected list column that references another table.
The lower() works fine for each column individually, but once I add some together with +","+ it does not play nicely.
Would any of you be willing to walk me through how to set up/write a formula for a super basic regex search? It would only need to search in one column based on the user’s input. I’ve been all over the playground docs and the discussion above, and it’s all about five tiers more complicated than I can handle yet…
Thanks @mallika I tried to create a doc to share but the domain associated with my work email won’t let me share it with anyone outside our organization.
I don’t suppose there’s just a formula template we could work on that I could plug the names of columns and tables into later or something?
This gets me most of the way there, thank you! I just have to play around with putting my own table/column names into the formula you have in the table filter. If I have any specific issues I’ll post here. Thanks again!
@Ben_Lee , I’ve got the formula plugged into my own table filter, showing no errors. When my search field is blank, it shows my whole inventory list which is great. However as soon as I add anything at all in the search bar I get “No results from filter” Here’s the formula as is with names from my tables plugged in, just in case you see obvious mistakes: If(SEARCH.[Column 2].First().IsBlank(),thisRow.IsNotBlank(),thisRow.Description.RegexMatch(SEARCH.[Column 2].Lower()))
When you type in your “search box” the value you want to search for, you need to then click outside that cell somewhere so it registers with the filter in the table.
The other thing that might be happening is Regex is case-sensitive. If you have a “Description” column, it might be worth making another column called “Description Lowercase” and using the formula…
Description.Lower()
You’ll see that this will make everything in description a lowercase value so it will match anything you enter in search.
