Hello!
We have a custom template we’re trying to use inside one of our docs and we’re getting the below error message. Any guidance on how to make it available for use in the doc? To note, it is not a multi-page template so I’m assuming there should be no issues.
Hi Sara,
At the bottom right of your doc, their is a button with a question mark. This will put you on contact with the Coda support staff. That is probably your best option.
Thank you, Piet! I have submitted a ticket and will patiently wait for them to return from holiday.
Oops, I thought the holiday is Monday.
Good luck.
