Help with ForEach() and Modify Row
Hello again!
I’m having an issue with the ForEach formula. I swear I’ve done something like this before, but I guess not. I know there are other ways to get the list, but for this project I need it to be a button that does this.
Basically, I have two tables: PODS & SPECIALTIES:
SPECIALTIES Table:
PODS Table:
The tables have a relation with each other (they’ve been talking about moving in together, actually). My goal is to have a button on the PODS table that takes the Number values from each SPECIALTIES object and makes it into a list in the Specialty Numbers column on the PODS table.
Desired outcome after pressing button:
Button Formula:
However, when the button is pressed, it only puts the last value into the Specialty Number column:
I’ve tried to change around the formula multiple times but I can’t seem to get it to work. Could anyone explain why this isn’t working as intended?
Hi Samuel,
I think you are overcomplicating it a bit. You can just use a formula without a button thisRow.[Pod Specialties].Number
If you really need a button you can use this formula then
thisRow.ModifyRows(thisRow.[Specialty Number],thisRow.[Pod Specialties].Number)
Hope this helps,
Pablo
Thanks for your response.
I know there are way easier ways to achieve this, but it’s just one part of a larger formula. In theory this should work, so I’m more looking for why it isn’t working rather than just a way to get the list of numbers, if that makes sense.
So what’s the issue actually? That the Speciality Number field might already contain another number and you don’t want to overwrite it?
:wave: @Samuel_Langford
with your button formula, because it’s used ForEach(), it overwrites the A (4) and B (5) one and thats why you’re left with C (6).
if you want all the numbers i.e. 4, 5, 6 then as @Pablo_DV has suggested, is to get the list combined and then just “stamp” (modify) the Specialty Number column once.
hope this helps!
Cheers!
Mel
REPOSTING THIS BECAUSE I ACCIDENDLY DELETED THIS RESPONSE
It’s kind of a lot to explain, and I can’t share the doc. But basically:
There is a third table called PEOPLE, each row there has a has a column that ranks their specialty interests (1st, 2nd, 3rd). So I need a button to loop through the list of Specialty column values, look for a student that has that interest as their first choice, and then stick them into a column called People.
So something like this:
But it’s only giving me the last value, instead of 3.
But if I’m using list combine, shouldn’t it stick the first value into the column, then the 2nd, then the 3rd?
Theoretically I think your formula should work, but maybe the result of the previous modifyrows() has not yet been stored in the database when you are already calling the next one.
I would recommend to do the listcombine() within the formula and then store the value with a single ModifyRows(). Something like this
thisRow.ModifyRows(
  ListCombine(
Amazing.
I got it working. Thanks so much!
@Samuel_Langford
what @Pablo_DV said below is correct.
i didnt explain it right/properly… its got to do with race conditions (how coda processes order of execution).
i tried a ._Delay() formula for you but it still just comes up with 6.
one of those coda quirks :woman_shrugging:
