Help with Pre-Filtered data from Relation Table
I have a table called Project which has display column as Project Number.
I have a table called Main Equipment where the Project column has a relation with the Project Number of the Project table.
Now, I have created a table called Item List. What I want to do is have a column from where I can choose the Project Number and another column which will only show Equipment of that particular Project Number.
Example:
Table: Project
Project Number
3230
3229
Table: Equipment
Equipment Name | Project (taken from Project Table)
Heater | 3230
Pump | 3229
Motor | 3229
So in the Item List, if I create an Item called Pad Plate and choose Project as 3229, in the Main Equipment would show Pump and Motor and not Heater.
Hope I was able to explain my query.
Thanks!!
Hi @Transtech_Collab and welcome to the Coda Community!
It’s much easier for me and others to help you if you share your doc with us. We can take a look into the formulas and everyone can make a copy of the document so we don’t get in the way of each other.
Please follow this guide to share your doc with us:
Jannis
Hi Jannis, thanks for your reply. I haven’t really created any formulae or data. I am just in the design phase and trying things out with sample data.
Thus, shared example with some sample data in my query.
Hi @Transtech_Collab,
sorry for the late reply.
I followed your intention and created something that is probably easier to use than the initial idea you had.
Please check if that fits your use case:
Please let me know if you need any more help.
Jannis
@Transtech_Collab
Please let me know if this solved your issue so we can move forward and mark this issue as resolved.
Jannis
