Help with 'Upsert' in Coda API
Hello everyone,
I’m sure this is a rookie mistake, but for the life of me I can’t figure it out. I’m just trying to upsert a row, but it always inserts a new one instead of updating the existing one with the same key column. Can someone please give me a hand?
Here’s a Loom recording with my test: Loom | Free Screen & Video Recording Software | Loom
headers = {'Authorization': 'Bearer '+CODA_API_KEY}
uri = f'https://coda.io/apis/v1/docs/{DOC_ID}/tables/{TABLE_ID}/rows?disableParsing=false'
payload = {
  'rows': [
      'cells': [
        {'column': 'c-LdNOdOjxic', 'value': 123},
        {'column': 'c-Yy758BC3B9', 'value': random.randrange(1,50)},
      'keyColumns': ['c-LdNOdOjxic']
req = requests.post(uri, headers=headers, json=payload)
req.raise_for_status() # Throw if there was an error.
res = req.json()
thanks!
Pablo
I’m just on my phone now but in the docs it looks like rows and keyColumns should be on the same level. You’ve put keyColumns inside rows
yep, that was it… :man_facepalming:t2: thank you so much!
Pablo
Awesome, glad I could help :relaxed:
