I have a filtered table item on a page, it returns one row which I want to present as two columns using detail view. All works fine but in addition to the two columns I also have the item ‘name’ in a first left column. This is usually useful but in this case I want to remove it. Is this possible?
I seem to have solved this now, although I have no idea how…
Originally, when I edited the layout, the left hand ‘header’ column was not shown, it only appeared on closing the editor; now it doesn’t show.
I played with quick styles none was exactly what I wanted - on the quick styles list the first is shown as selected and I can force the left hand column to show using the sixth quickstyle, but if I then select the first I get a single column of fields instead of my preferred double column layout, so I undo to return to what I want.
So , great that I have what I want. Mystified how I did it!
