hi,
i’m trying to create an hourly timeline with tasks assigned to a person/org lined-up in the same row for each day as per sample diagram below -
if it can be done, may i get a guide fr that, pls?
tks,
-nik
hi,
tks,
-nik
Hi Nik,
You could do that in a two step process.
First is a table with a row for each date/hour/employee.
Then you create a new table. This second table consists of columns for each person/hour, driven by a (for example) canvas filter.
Hope that gives you some ideas.
P
many2 tks fr yr replies, @Piet_Strydom & @Aurelie_Pureur1
let me try the suggestions again & i will revert in due course.
krgds,
-nik
hi again @Aurelie_Pureur1 / @Piet_Strydom
i have created a table as per weblink-
it’s to show that what person (aa-a) does in 1 day in 1 row-timeline
the objective/intent is to create a timeline view that shows routes flown by each aircraft registration (regn) on a single line for each day (date) as shown in my sample earlier.
in the sample table (via the weblink), there are 2 aircraft registration (2 regn’s) & therefore the timeline view shud reflect 2 lines (1 for each aircraft registration or regn).
the timeline view may b created in another table.
task starts with std & ends with sta, if possible.
apprec if u can assist me here.
tks & krgds,
-nik
