See the doc below: once I press the “track time” button, I would like to select the “company” and then have ONLY “projects” that are associated with that company display as options to select.
Is this possible?
Hi Demetrius
The page “Lookup 1- From one table to another, with filters” in the doc below should give you what you are looking for.
Regards
Piet
