I want to increment the value of a number column in a table (among other things) using an automation event.
I’m assuming the ModifyTable formula is what I would use here. This is the example in the docs for using it: ModifyRows(Tasks.filter(Status != “Done”), Status, “Done”)
When I try to use something like this: ModifyRows(Tasks.filter(Status != “Done”), Count, Count+1), it doesn’t work.
However, this will work: MModifyRows(Tasks.filter(Status != “Done”), Count, 10)
Any help on how I can get this done?
Dear @Rahul_Jaisheel,
Please see the screenshots for inspiration:
Then I created the simple button just to add a row as below:
Then create an automation rule to push the button every day at a certain time as in the screenshot:
And as you can see, everyday the automation is executed;
I hope I have put you in the right direction
Success,
//JP
Hey Rahul_Jaisheel!
The issues is that ModifyRows is not “at” any particular row, and you are assuming it is. ModifyRows is likely just trying to apply a value to the reduced set made by your filter, by filling a whole column with the value you set, such as “10”. When you say “Count”, which “Count” do you mean?
We need to think of a way of making sure ModifyRow was only looking at a single row at a time. For this, FormulaMap is the solution:
Tasks.Filter(Status!="Done").FormulaMap(ModifyRows(CurrentValue,Count,Count+1))
To demonstrate the function I used a button, but I see no reason this won’t work in an automation event.
PS - Ignore the type error given in the formula. Coda devs are working through this.
Lloyd
Impressive input
thanks sharing your know-how.
Hi @Lloyd_Montgomery,
Thanks for your suggestion, this does what I want it to do. The “Count” I was referring to was just the name of a column, just like you have used it.
I had made a button column in the table to increment the Count column of ‘thisRow’. I then made the automation event click this button row. This works, but having a single formula is certainly a more elegant solution.
Hi @Rahul_Jaisheel,
A button in the row itself makes this a lot easier, and works for most situations. I recommend this for most custom solutions
Happy you figured out something for you, and that you also like the formula I propose.
Lloyd
