How to convert a number to binary?
This is just for fun!
What’s your best formula for converting a number to a binary representation?
E.g. if you are given 24, you should output a list like 0,1,1,0,0,0.
Leading zeros are ok. Can be big or little endian (meaning, the 1 place can be on the right or left).
Looking forward to seeing what you can come up with. I struggled quite a bit with this, it was fun :slight_smile:
You can see mine doesn’t handle 0s as input very well :confused:
Hi @cnr
first of all, I officially hate you! :smiley:
I had a lot of work to do today and you infected me with this trick.
I came up with this solution:
Basically the formula is:
If(Number = 0,0,
  Sequence(Log(Number, Base).RoundDown(), 0, -1)
    .FormulaMap(CurrentValue.WithName(step,
      RoundDown(Number / Power(Base, step)).Remainder(Base)
   ).Join("")
Now I’m curious about yours (and others’)! :grinning:
Edit:
Slightly changed for multi-base conversions
And multi-symbol…
Ok, now I really stop.
:blush:
Woooooow! That’s so cool! I didn’t even think to make it multi-base. I figured it would be much more complicated, but it’s basically the same as the original algorithm.
Well done! The use of Sequence(start, 0, -1) is very clever! Nice work :slight_smile:
Here’s mine for binary only:
Sequence(0, Ceiling(Log([expected outcome], 2))).ReverseList().FormulaMap(
  If(IsOdd(Floor([expected outcome] / Power(2, CurrentValue))),
    1,
    0
Yeah: it’s basically the same.
I was very curious because without recurring functions is always quite tricky.
Remainder() instead of IsOdd() acts as the multi-base enabler, this is the only substantial difference.
Let’s see what come if somebody else is compulsive enough to spend some time on it :wink:
Yeah I was also confused how to do it at first without recursive functions. All my base changing algorithms have been recursive. Fun (and surprisingly easy) to do it as a loop.
Another way to do just the binary: convert to hex using existing formula, then take each hex number and convert it into 4 bits e.g. like this:
ToHexadecimal(312).Split("").FormulaMap(
  Concatenate(
    If(Find(CurrentValue, "89ABCDEF") != -1, "1", "0"),
    If(Find(CurrentValue, "4567CDEF") != -1, "1", "0"),
    If(Find(CurrentValue, "2367ABEF") != -1, "1", "0"),
    If(Find(CurrentValue, "13579BDF") != -1, "1", "0")
).Concatenate()
Another version, less hardcoding:
  CurrentValue.ToNumber(16).WithName(Hex,
    List(8, 4, 2, 1).FormulaMap(
      RoundDown(Hex / CurrentValue).Remainder(2)
).ListCombine().Concatenate()
Once you get out of decimal, it’s easy to do oct <–> bin <–> hex.
My assumption is that ToHexadecimal would be much more performant (a native integer loop or whatever) than calculating powers and dividing by those
