How to create "Next page" buttons
Hi,
I want to insert buttons that send you to the next page in a playbook I am working on in Coda. Is there any better way to do it than by copy-pasting the URL of the page?
Anyone knows also if the URLs are automatically updated in the buttons when the website is published?
Hi @Lucie_Le_Naour and Welcome to the Community :partying_face: !
Well, sadly there’s no thisPage we can reference/get the url from so, not really :sweat_smile: …
But, you could create a “navigation” page with:
  • A canvas formula storing the Doc URL using something like :
    thisDocument.ObjectLink().ToText()
  • And a table where you store the @ref of each page you want to open with a canvas button.
    • From the @ref of the pages you can then get the Page ID (the one used in a page url) using :
      thisRow.Page.ToText()
    • And then you can re-create the full url of a page and use it in an OpenWindow() button
  • Your canvas buttons can then push the appropriate button to open a page
See the sample below :innocent: …
The Doc Explorer Pack might also help you with this :blush:
And these 2 topics could give you some inspiration too :blush: …
As for this …
… I think that instead of using the Doc “internal” url, so the one returned by:
Which outputs something looking like :
https://coda.io/d/_dDoc_ID
You would need to use the published doc URL
https://coda.io/@username/doc-title
… and probably use the published Page IDs (which Coda creates automatically) in the navigation table … or just the full URL of each published page you want to open with your buttons.
But I don’t think the url are automatically updated though … Hence why using a table might be a plus (as you would just need to update each URL once instead of modifying each buttons :blush: )
I hope this helps :innocent: …
Thank you for your help @Pch :slight_smile:
My pleasure @Lucie_Le_Naour :grin: !
