How to export records?
Hi all, I’m new to Coda and considering to port over from Airtable. There are some things Airtable can do that Coda can’t, vice versa. I was playing around with the Invoice doc template and got the layout that I want. The question I have is ‘how do I export a particular invoice record?’ I didn’t want to download the whole doc as a page and only want a specific invoice record so I could send an email to my customer.
FYI, I was using this template > https://coda.io/t/Flexible-Invoice-System_tk4xB4FCFaS
Hope to get some insights from you Codan gurus. Thanks!
Dear @Brendon_Koh,
It’s rather depending on the format / why you want to export.
There is an option to get the invoice record in a detail view and to add it to a mailing list to be distributed.
It’s possible to print (to *pdf) the same
If you want to export it to and Excel compatible format like *.csv it not (yet) possible and I don’t know if it’s on the road map at Coda.
HI @Jean_Pierre_Traets,
As attached, when viewing a row in detail view (which is already in the invoice layout format), how do you export it to PDF?
Dear @Brendon_Koh,
Here you will find the print option:
I recommend to create a section that you use for printing, to be able to adjust the lay-out as good as possible to your expectations.
:printer: Just to be fair, there is space for improvement from Coda
Hi @Jean_Pierre_Traets,
Agreed that the exporting is something that needs to be improved on.
I guess at this point of time, using integration to pull data out to template generators seems to be a more viable option.
Thanks anyway!
F.Y.I.
Just following up on this now. Is there no way to export a table as a csv quickly and easily? Am I just missing it?
Thanks,
Tom
Dear @Tom_Huber,
There is no function to export tables to *.csv, Coda just recommends to copy paste the table to the location of your choice.
Hey @Tom_Huber! If you’re still looking for a way to export you Coda tables to excel or csv, my company made an integration for Coda that allows you to make a button to export your tables. The website is codaexport.com. Let me know what you think!
