How to filter Lookup options to omit duplicates
When I use a lookup from a table that has grouped items, I often only want to select one of the many duplicate names in that table. How do I filter the Lookup options so that only one unique option shows up.
I have already tried Item settings -> Filters like:
[Target Table].Unique()
Name.Unique()
[Target Table].Filter([Target Table].Name.Unique().FormulaMap(RowId(CurrentValue)).Contains(CurrentValue.Name.RowId()))
None of those work
@Connor_McCormick
Sounds like a schema problem, but without seeing a dummy doc, it’s tough to say.
Here’s one possible approach:
Clever! Thank you. Is there any way to do the same thing directly in a single item filter formula?
There’s probably a way. Whether it would be worth the overhead or not is another question.:sunglasses:
Tough to add much more without understanding a specific use case.
No problem, thank you for your help.
The essential usecase is a way to build out packages containing multiple components. I want to be able to select the packages and then order all the internal components (without having to select the components individually). Does that make sense?
Sounds like a schema issue. If you want to mock up a dummy doc with the same structure, or share something offline, I’ll take a look for you.
Happy to share the real thing, it’s all dummy data anyway. I’ll private message it
Hmm, won’t let me message you privately. It says your public profile is hidden. What’s your coda email address?
@Ander, thank you so much for your help! For those wondering, the solution in this case was to normalize the data.
@Ander Maybe you can make a quick How To post on what normalization is and how it works.
