How to generate uuid? any uuid()?
Hi @Kepler_Liu,
unfortunately there is no UUID formula at this stage.
I don’t know what is your use case, but maybe this could be relevant:
In Table, use Split(thisRow + "", "/").Last() to get the uuid of that row.
But in formular, can I generate the uuid by compositing some functions?
@Kepler_Liu,
as said, outside of that context, at this moment no programmatic generation of UUID is available.
If you can share your specific use case, maybe there are some useful workarounds.
I want to send http request to my server, which the params of the url supports ?id=uuid.
While Coda is not supporting http request, I use Image(url) as http request pack.
I would like to turn my doc into dashboard. I can trigger workflow of my backend server from the button.
Saw myself mentioned here. I remember I solved something similar here:
