How to get multiple column from filter formular?
Hello Friends,
Is that possible to get multiple columns from the filter formular ?
I am trying to do the follows:
I have a feature list table per project
And I want to filter and display Feature List for each project
ie:
Project |  Feature List
   foo       a:1
             b: 2
             c: 3
  bar       alpha:100
The best I can eke out currently is using filters and bullet list, but seems only the feature name is displayed, I couldn’t figure out how to lookup and reference to other columns other than the display column. It is like this
foo          a
             b
             c
bar         alpha
The sample doc is here:
Is that possible at all ?
Cheers,
    Marvin
@Marvin_Wu1
Here two other ways you can play with this concept.
@Ander Thanks a lot Eric! This is exactly what I am looking for and even more,
appreciate the help very much,
   -Marvin
