Hi, Is it possible to show the same Control Select filter in more than one place? I know I can use a formula to show the options selected from another but I would like to be able to change the options in two different places. Is this possible? Tony
Hey Tony,
The only way to do this now is to use this approach:
Hi @Paul_Danyliuk,
Thanks for the reply, I’ll check this out.
Tony
