When filtering using a dropdown selector with single select think I’ve found a way to make the selector show everything instead of nothing: when selecting [Blank].
If([Select Name]=“”,True(),thisRow.[Column].Matches([Select Name]))
Using this formula, the filter will use the selector unless blank (“”) is selected.
As I find the multiple selector a bit complicated to use, this should be a good alternative.
