How to Modify List Option Based on Column Formula
I’m guessing this has been asked before (and is probably really simple), but I just couldn’t figure out how to word it. Essentially, I want to make an output (and eventually a filter, but that comes later) of a column based on other column data.
I made up a quick mock up here: Coda | A new doc for teams.
I want the 3rd, final column to auto-generate the “status” based on whether or not a previous column is blank. In my (personal) doc, I have numerous software licenses that are either unassigned or assigned, and I was hoping to auto-generate a column that tells me that based on whether or not I’ve given a particular software license a home.
Please check column Status 2 a sample of a working formula.
Greetings,
Joost
Yes, thank you! That’s exactly what I was looking for :slight_smile:
