I have two tables (with a many-to-many relationship): Contacts and LogEntries.
How can I select multiple contacts from my Contacts table and (with the press of a button) create one new log entry in LogEntries that automatically links that new log entry to all the selected contacts?
Thank you so much for you help and support!
Dear @anon7107569,
Would be great if you could share a dummy doc (no sensitive data) and I am sure we will be able to support you the soonest.
Edit: *Please add it under “ask the community”
Set the button to add row to the desired table (log entries) and set the value of the “contacts” column (in the button settings) to [contacts table]. Filter([checkbox])
Hope that’s clear enough, if you need further assistance, it would be helpful if you share a dummy doc, as @Jean_Pierre_Traets said
You can also set the button to clear the selection after adding row to the logEntries table by setting its action to:
Runactions(AddRow([LogEntries], [contacts], [ContactsTable].Filter([checkbox]),...,...), ModifyRows([ContactsTable], [checkbox], false())
*I’m on mobile, hope there’s no errors in the formula
