How to show the years of Duration?
115 years
24 years
14 years
Thanks.
Hi @Steve_Yang,
I post this some time ago (though I can’t find it…):
It’s a workaround implementation to show durations longer than a day.
Let me know if it’s useful.
Cheers!
The trick is concatenate()
And if()
Thanks @Federico_Stefanato
Coda should add Years ,Months duration option. .
Thanks @Steve_Yang, @Federico_Stefanato for the trick but the result is text. It will therefore be impossible to use the value in a formula, apart from having 2 columns: 1 text, 1 duration.
Does the Coda team plan to add months or years to the durations?
