How to write a " " " inside a coda formula?
So need to chain up:
<.a href=" + Link + " </a.>"
A normal html link looks like:
<.a href=“https://www.linkedin.com/”> Link text</a.>
So if i do:
<a href=“”“https://www.linkedin.com/”“”> Link text
I get an eror.
Anybody an idea?
Thx
Hi @Isebar_de1 - Here’s 2 ways to do it:
Escape double quotes using \
Concatenate("<A href=\"", Link, "\">This is a link></A>")
Use Single quotes for your strings
This allows you to use double quoties " without needing to escape them
Concatenate('<A href="', Link, '">This is a link></A>')
Also you can use the format function with allows you to have 1 string and define variables in the string and then add the values of the variables as arguments to the function.
Format('<A href="{1}">This is a link</A>', "http://coda.io")
Thanks again @Ryan_Hubbard1
