Hyperlink formula does not work when referencing a column for the link
I have a two column table
  1. Calculate column called “Form Link” - the formula is Hyperlink(thisrow.URL,“Form Link”)
  2. URL - This is a Link field that has the link for that record.
If I use the hard coded value in Hyperlink(“http://google.com”, “Form Link”) it works. However when I give a column reference it does not populate the link.
I found the issue. In the canvas column where I was doing the mail merge I had made the {6} parameter as a link in the format. Thus was not working.
