I’m trying to build a to-do list with recurring tasks. I have a “Recurring” column where I can put in the number of days I would like the task to recur. When I hit the “Completed” button, it triggers an IF formula that figures out if the “Recurring” column is greater than zero. If it isn’t, it treats it as a normal task and just marks it complete. If it is greater than zero, it is considered a recurring task, which triggers an “Addrow”, which basically duplicates the active row. I would like to also modify the active row, marking it complete, but I can’t figure out how to create a formula that does both Modifyrow and Addrow.
Here’s the formula that I’ve built so far.
if(thisRow.Recurring>0,AND((AddRow(thisTable,thisTable.Category,“Recurring”,thisTable.Status,“Active”,thisTable.Task,thisRow.Task,thisTable.[Start Date],thisRow.[Start Date]+thisRow.Recurring,thisTable.[End Date],thisRow.[End Date]+thisRow.Recurring,thisRow.Recurring,thisRow.Recurring)),(modifyRows(thisRow,thisRow.Status,“Complete”))),ModifyRows(thisRow, Tasks.[End Date], Today(), Tasks.Status,“Complete”))
Here’s a copy of the Doc as well:
Thanks for the help!
