Hello,
I’m looking to roll my Monday.com setup into Coda but I don’t seem to be able to figure out if this is possible.
Ill take a small screenshot showing how our Monday.com board works (ignore the data inside its just for example) but as you can see, there are different columns inside each of the parent and subitems. This is important to us for keeping things clean.
What I really need to know is - Is this possible inside Coda? Can I replicate this or not?
Many thanks for any help!
J
From my short experience working with subitems I would say no, this can’t be done. In order to do so you have to work with sub tables, but those cannot be displayed with the parent rows in one table.
So I think this layout cannot be replicated.
If you need this functionality, I’d build two tables, one for parent tasks, one for subtasks, and link them via relation columns. You won’t be able to see the subtasks nested under the parent tasks in a single view, but you can pop open the parent task modal (an opened row) to see the subtasks in their own table.
