Is there a similar functionality to Confluence's Excerpt Macro
I’m looking to see if there’s any functionality similar to a feature in Confluence, which is the excerpt macro, which allows an arbitrary piece of content (for example, a single sentence in a longer document) to be marked as an excerpt. That text can then be included in another page.
I’ve looked at the Include macro, and can pull in an entire page or a section (based on a heading), but not an arbitrary portion of a page. Does anyone know if this can be done, and if so, how?
Appreciate any help on this
Hi Faris
Short answer - it is not possible.
The closest you can come is to define, in a table, pieces of text, which you can then pull into a page or other table using a formula. But not in the direction that you want to go.
