Is there a way to automatically create a 'table of contents'?
Hi all,
I’m using a Coda doc at the moment to build myself a notebook so it’s got a lot of long sections each with a number of headings for different topics.
Is it possible to create a ‘table of contents’ at the top of a section based on the h1, h2, h3 elements so I can easily see a list of topics and jump to them?
+1 for this feature request .Looks like it can’t be done right now.
You can use /Outline on a page to create a floating Toc in the top right hand corner of the page. It unfortunately does not work on canvas columns.
That helps. Thanks @Piet_Strydom !
