Is there a way to close activated row using a button
I know there is a way to activate or open row for editing upon clicking a button. But I’m wondering if with there is a way to do the opposite of opening a row for editing.
I’m trying to build a system where I can click one button to add a row and edit it, then click a “Done” button that will close out the row open for editing.
I hope this makes sense.
thanks for the help,
Hi @Ethan_Liston :blush: !
Yes, this is possible by using something like this in your Action formula :blush:
OpenWindow(thisTable.Url())
You could also use a “canvas landmark” and the url of the landmark instead :blush: …
I’m not exactly sure how this might work on long table though as I’ve only used this on small filtered tables fitting my screen :innocent: …
Hope this helps :blush: !
Wow, this works for my project.
thanks for your help!
No problem @Ethan_Liston :grin: !
I’m very glad to know this works :raised_hands:
