I’m trying to Export my table as a CSV, but I don’t see an option. What am I missing?
Dear @Amir_Banihashemi ,
For the time being there is not such a function integrated in Coda.
A suggested work around is to copy your table, paste it in a spreadsheet and save as *.csv format.
Also I would recommend you to add your vote to the following suggestion topic to provide a better visibility of this much needed feature
I probably shall add that I’ve been experimenting with a piece of logic that would take a view and export it as CSV:
Big chance is, I’ll package it as an easy-to-set-up template and share it as a Monthly Patron Special with my patrons ![]()
Hey @Amir_Banihashemi! If you’re still looking for a way to export your tables to CSV, my company made an integration for Coda that allows you to make a button to export Coda tables to Excel or CSV. The website is codaexport.com. Hope it helps!
Hey all! As an update to my previous reply, I’ve turned the export tool that I linked to above into a Coda Pack that you can add to your doc to export tables to CSV or a few different Excel formats
