Issue with adding new rows when grouped by lookup
Hey all,
So when I press enter at the bottom row of a text group there will be a new row created within that group that can be typed into immediately.
When I try the same with a group based on a lookup there will be an ungrouped row created below that will not respond until I’ve deselected it.
Here’s a doc highlighting this. Let me know if there’s any workarounds
Edit: The issue also happens with select list groups
@Avery_Becker
It’s worse than that, actually. In your sample doc on the grouped table, if you hit enter on the last row of the Type 1 group, the new focus cell jumps all the way to the bottom of the table (which the user wouldn’t even see if the table ran off the screen). Then, after clicking away from the newly created cell with focus, the newly created row jumps back into its proper grouped position.
I don’t recall this behavior existing previously, so maybe it’s newly introduced?
I was running into a similar issue yesterday that had to do with cell focus within a grouped table. It caused a moderate headache that I had to go back and fix manually. Basically, I was copying text in one grouped cell to paste into another grouped cell. Upon clicking away from the cell where text was being copied (removing focus from that cell) and clicking onto the cell to receive the pasted text (putting focus on that cell), the text in the cell where text was copied from got deleted. That empty grouped cell caused the row to jump elsewhere in the table. Because of the size of the table, I didn’t see any of this behavior taking place until after I had already made a pretty big mess!! :crazy_face:
So, yeah, something seems to have changed with the behavior of grouped tables…
@mallika
@Ander @Avery_Becker - thanks for bringing this to our attention. It is a bug we are working actively on fixing and hopefully will have it done soon. It is annoying and definitely impacts data entry!
I’m still having this issue :frowning:
