I have a table with meeting agenda templates in a canvas field; and another table for hosting meeting minutes for each meeting. The way it works is I select the meeting type, and the agenda copies over from the first table into the second table.
Within the canvas are some reaction button for voting on topics. These works fine for a few weeks; but then found recently that the objects within the meeting minutes can no longer be copied/pasted. When you copy and paste an existing reaction button (e.g. to add another row with the same format) - the reaction button pastes “Object Not Found!”.
Have other folks ran into the same issue?
Hi @Erica_Anderson , thanks for reaching out and apologies for the delay in response. I escalated this to our bug testing team and they were unable to see the “Object Not Found!” error you mentioned.
They tested by copying 2 rows from a canvas column that contained reaction controls inside and pasted them on another table with a canvas column, and the result was the following shown in this screencast:
Screen Recording on 2024-09-20 at 12-42-49.gif - Droplr
If you’re still looking for a solution here, I would recommend reaching out to the Coda Support team by clicking the ? in the bottom right corner of your Coda screen and submitting a bug report with this information. They also requested the reproduction doc and reproduction steps for further testing. Thanks in advance!
