Hi,
I want to add a comment in a detail view but it jumps to the related row.
Video here: https://www.loom.com/share/8fe94415fc644ba2aa8cbb21afc20177
I have quite a lot of bugs in the detail view. Will share more.
Lars
Hi,
Lars
Hi @lars_hofstetter_10TIMES_io , thanks for reaching out. It appears as if this is working properly from what I can tell from your video. Can you please describe the actions you’re taking when encountering this behavior and what you’re expecting to happen instead?
It looks like you’re secondary clicking a cell in your table view, then it opens up the row modal when you click “Add Comment”. Is something different happening?
@Shaina_Torgerson
I was expecting that the comment opens on the right as a box. see screenshot:
I guess the idea is that the row opens and I add a comment at the bottom? not so intuitiv to me…
