Launched: Codepen Pack
This pack embeds the RESULTS pane of a CodePen project in your Coda Document using formulas such as Display('AxFFg3e')
If you are not a PRO member in Codepen, then you must be logged into your Codepen account elsewhere to enable access via the Coda Embed.
Hi @Max_OBrien - Sounds like a cool Pack! The link above doesn’t work though, perhaps it’s not been published?
oops - du-huh - !
try now?
Yep, now it works! It’s on us to improve the visibility of the published status.
