Lay out two tables side by side
Hi all,
My first post. I’m enjoying my Coda experience so far and learning all the time. I have two tables, which are essentially the same structure but the key column in each is a lookup from two different tables. Ideally I would like to place these two tables side by side rather than one under the other… Is this possible - I do have the screen real estate.
Many thanks,
Denis
Dear @Denis_Brennan,
As you know “Coda” is still in Beta. :bulb:
It’s not (yet) possible, but on the roadmap :world_map:.
Gradually new features will be rolled out over the coming weeks and this should be one of them.
Be patient, explore what is already possible :sparkles: you will be amazed :rocket:
Enjoy Coda,
Kind regards,
Jean Pierre
Jean-Pierre,
Many thanks for this. I am enjoying it and will continue to experiment. I have another question but will post it separately to avoid corrupting this thread
Best wishes,
Denis
Two graphs side by side would be great too.
Hey @Samuel_Peret @Denis_Brennan
Just noticed this (posts from Misc are hidden from notifications by default, for some reason). Maybe this will help:
Won’t take up the full screen real estate, but it’s always possible to expand the view temporarily into full screen mode.
