Hi all!
Is there a way to make a list in Coda that’s lettered (A, B, C…) instead of numbered?
For example:
A.
B.
C.
instead of:
1.
2.
3.
I’m wondering if there’s a Pack or simpler trick for this so I don’t have to do it all manually. Or this could be a Feature Request as well. Thanks!
@Ruby_Ren
welcome to the community!
its easy to trigger the numerical bullets/indents of 1, 2, 3 etc. but for A, B, C you cant.
However, i found that if you do 1. and then enter and press tab, it will create “a.“, then when you hit enter, it will create “b.” and so on.
Then you can go back to the the line with 1. and delete it. The a, b, c indents will remain.
Please note, its lower case letters and not the capital versions like you initially stipulated.
hope this helps!
Cheers!
Mel
Thanks Mel! That’s really helpful! Wish Coda will have lettered lists built in as a main list option someday. Not sure Coda Team will see this or not, but would love to send a Feature Request here as well
