Limiting the returned data with RunActions
I’m trying to limit the data returned for a view of our tasks, but I’m running into an issue.
Here’s how it currently looks :point_down:
The Recent Updates button works, but it shows a long list —I’d like to limit it to the 10 most recently updated tasks.
I’ve tried different approaches using Slice(), but nothing has worked quite right, and I have a feeling I might be overcomplicating this.
How would you go about limiting the results?
Here’s the current code for the button:
RunActions(
  ResetControlValue([View Tasks Due Date]),
  ResetControlValue([View Tasks Assigned]),
  ResetControlValue([View of Tasks Status]),
  SetControlValue(
    [View Tasks Modified on], List(Today() - 7, Today())
Dear @Edan_Ben-Atar,
This post shows you how to limit the result according your needs.
Thanks! I’ve been reviewing that thread but haven’t had any luck applying it to my case.
Here’s my latest attempt:
  // Set the date range filter to the last 7 days
  SetControlValue(
    [View Tasks Modified on], Slice(List(Today() - 7, Today()),1,10)
Please mind sharing a dummy document,
much better chances to receive adequate support.
Here you go: https://coda.io/d/_drzaWtfeLxy/Tasks_suqjE9cB
Thank you sharing the doc.
You should add one more filter to the table as in the screenshot below:
and this is the formula: thisRow.In(thisTable.Sort(true, thisTable.[Due date]).Slice(0, 10))
For a detailed explanation how it works, I recommend you this post of Shishir:
I will not be able to explain it better then him
Hi,
I made an example a long time ago: :slight_smile:
You can use same principle
