Load times & responsiveness especially on mobile
Hi folks,
I’m looking at speeding up load times, especially on mobile with limited data speed. What’s fine on a desktop/laptop with good connection can be more than a bit tedious on the move.
The built-in AI has pointed me towards the number of formulae on the main table in the doc, as well as reducing the number of views and pages. This seems reasonable but can I ask for a bit of fact-checking to help identify the best things to streamline first:
  1. Is it true that all formulae are calculated for a given row, even if they’re hidden in that view, and the one or two columns are visible to that view that don’t require the formula information?
  2. Is it true that having more pages in a doc - even if they are hidden - will slow down the load of a given page?
  3. Is it true that all views of a table arranged on view tabs have to load before you see the first tab?
Anything else to point me towards with this in mind? And are there any tools/extensions to help identify which elements are causing the load time?
With thanks,
David
Hello @David_Walter ,
These are good questions, and they are really important when a doc gets bigger.
I am not a Codan, but a maker, and I ran into these exact same things when some of my docs reached a certain size.
The following are, as far as I know, the answers to your questions:
  1. That is true
  2. Mostly true: it does not slow down the load of a given page; it will slow down the load of your doc. Once the doc is loaded, pages open up as quickly as in a small doc (given enough memory and a quick processor on your mobile).
  3. True (actually, in Coda (SH Docs), this is the same question/answer as question 2
My largest doc became, at some point, unusable. I had been adding many formulas and many views to allow for slightly different uses of my docs and tables. To get my doc to perform better, I limited the number of views drastically; some views I replaced by using filters on one of the views. For some tables, one view with proper filters replaced 5 of 6 views (each of them hurting performance, while filters seem to work more efficiently).
Deleting some formula columns also gave a lot better performance. This is a tradeoff; sometimes the calculated columns are really helpful, but sometimes you can do without. Running an automation at night to update fields that were calculated before can, in some situations, be a solution (but I do prefer real-time for most calculations).
I am desperately waiting for the new (in beta now) database functions that might resolve some of the issues.
There has been talk of not loading all pages when opening a doc to resolve some performance (or security) issues, but it’s been quiet on the front.
Greetings,
Joost
Brilliant, thanks Joost :slight_smile:
